- Thread starter
- #26
97_4g63t
Supporting VIP
- 472
- 49
- Jun 6, 2010
carlsbad,
New_Mexico
I didn't. I could if anyone really thought I should. I'll have to order a new fpr so car is gonna be down till that comes in at least.I think at 130 we can say you probably didn't hurt anything too badly internally... I could be wrong here, so please chime in if you have conflicting experience. With all the fuel washing the oil off the rings, 130 seems pretty reasonable. did you try a wet compression test? just curious?
Will do. Thanks for all the advice guys I appreciate it.I agree with @rabenne. All at 135 is okay for dry and lower compression or loose ptw forged slugs.The leakdown test would be reassuring of the headgasket, but otherwise the only concerns I'd have would be the main and rod bearings. I think your idea of running some cheap high detergent oil through it would be a good idea, along with checking for any glitter/bearing material right away after doing so. Might also check the starter and the flywheel teeth.
