Brandonjffrs96
- 116
- 22
- Nov 2, 2019
Bronson,
Michigan
thats what my brother said, how do i check that?That's a 1g cam angle sensor. It doesn't necessarily mean your engine is a 6 bolt. Easiest way to tell which block it is would probably be by the oil pan.
This is a difference between 1G and 2G engine blocks, not necessarily a difference between 6- and 7-bolt. Remember there were 1G 7-bolt engines. And the 1G 7-bolt block is, in some ways, like the 6-bolt engine, including how many bolts there are connecting the block and transmission.Also, the 6 bolt block is more skinny and has one less bolt for the bell housing. It can be seen if you still have the transmission from the 7 bolt connected.. You may see a missing bell housing bolt just under the #4 cylinder exhaust port area (front of engine passenger side). The bell housing from a 7 bolt won't match up exactly with a 6 bolt block.
A Honda distributor will even fit there
