CAM280
- 49
- 11
- Oct 6, 2019
BRISBANE,
Australia
Hi Miguel, thanks for the entertainment, how much was your initial investment may I ask? In regards to the leak, are you sure its from the transfer case? I thought it had a different coloured fluid to Transmission fluid. Its possible the leak is coming from the drive shaft seal. If you ever want to do a rebuild on the tranny I can get cheap gasket overhaul kits. Thanks again for the 1gina2g kiggly crank sensor. My little beast is finally out of its 3 year coma and is recovering nicely just waiting on ECMlink to get it tuned.
