canadagst
- 0
- Jun 3, 2020
Toronto,
ON_Canada
Hi, so this is my first post but have been reading on here for a while. I have a 97 Spyder automatic. I have done all the required safety for the car. Also timing belt, water pump, motor mounts, brakes, lines, oil pan, thermostat plus much more. Added a hks exhaust with new down pipe also. COMPRESSION ENGINE IS IN THE 170'S. Turbo lines all good. Side mount cooler cleaned also.
I asked if I can install a Garrett t28 just for a mild upgrade and plan to boost to 14. The shop said I WOULD need to upgrade injectors if I plan to and need a ECU because it will run lean. But he says my biggest issue is that's its a AUTO and the tranny will operate like shit =.
What option do I have to get some more power into this auto? Do I have any ? Do I need to upgrade the tranny to do so? Looking for 275 to 300 hp and would like to know what is my best and safest way? or do I need to buy a 5 speed to get into more hp Thanks
