Boomdeeze
- 2,141
- 374
- Jul 5, 2009
Independence,
Minnesota
Just want your guys opinion on this nitrous system if/when I decide to pull the trigger. I recently upgraded my setup from an Evo3 intake/kelford 264 cam/#8 PI converter to a Magnus V4/Kelford 280/#7 PI converter so I am feeling as though I will need a nitrous kit to get up on the converter.
Will mostly be using it to stall up but also may spray out the hole in the future if I am feeling spunky! Do you guys that run nitrous also run a purge kit or is that just for the looks?
Here is the kit I am looking at, I like the simplicity of the push button activation rather than the WOT activation:
https://www.nitrousexpress.com/mainline-efi-single-nozzle-system-with-10lb-bottle-ml2000.asp
Let me know what you think or any recommendations!
