Dzducky
- 2
- Oct 2, 2019
Lake Elmo,
Minnesota
Sorry for the long read.
But this is the issue I’m currently having for my car, or what I’m noticing about it.
During wide open throttle or doing a pull on the car, the knock sensor will ping and cause the cel to go on, and the car is restricted to go any faster. Boost is also decreased by 3-4psi when that happens. During regular driving the knock sensor will go off randomly not making a difference on drivability of the car.
When idling it will ping after a while of sitting until I start driving.
What I just started to notice is that when it’s idling after driving, and the ping appears, I would put the heat on max and after a while it would disappear, but would appear again after I turn off the heat etc.
Hoping that it is the head gasket going out, or maybe I have to retorque the head studs again.
I have a idling video of the cel going on and off, and a video of the coolant reservoir.
I don’t know how to post videos, so you can pm me if you want to see! Thanks for the help in advance
