mk2davis
- 35
- 1
- Dec 7, 2018
NEWBURY PARK,
California
I've lurked around this sight for a while, and have asked some smart and some no-so smart questions. I finally got things sorted with ECMLink and my LC2, so I'm ready to start setting baselines and then tune! Below is the idle log after a drive, please let me know what you think. But First,
1). Any boost, vac, or exhaust leaks?
No
Boost leak tested 5psi above your max boost with no leaks?
Yes, 20 pounds
2). Verified mechanical timing?
Yes
3). Verified base timing?
Yes
4). Ignition system
Stock
Wire brand and Age: Magnacore/1 year
Spark Plug brand, type and Gap: NGK-BPR6ES/.028
5). Motor health (Compression Test)
unknown
6). Performed basic throttle body adjustments?
Idle Switch: Yes
Throttle Cable: Yes
TPS: Yes
BISS: Yes
7). Compression ratio
stock. I think for GVR4 its a lowly 7.8:1
8). Any known bad sensors or brittle wiring?
No
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running): 12.4 volts
Car running: 13.9 volts
Base Fuel Pressure: 43.5 Running a 2G FPR
Injector Size (cc/min): 450
Sensor Brand: LC2
Calibration Date: Yesterday
13). Type of fuel
Type: 91
Percent of Ethanol: unk
14). Watched ECMlink how-to videos?
Yes
No
Yes, 20 pounds
Yes
Yes
4). Ignition system
Stock
unknown
Idle Switch: Yes
Throttle Cable: Yes
TPS: Yes
BISS: Yes
No
No
Sensor Brand: LC2
13). Type of fuel
Type: 91
Yes
