SasaniFab
- 2,433
- 782
- Dec 1, 2013
Mexico,
Connecticut
So I finally decided to take the plunge and do the swap. For a auto car you need a 6 speed diff, the cups and stock rear axles. The axles need to be shortened , dss offers a set of bars made out of 300m.The 1g driveshaft flange needs to be drilled into the 3000gt pinion flange. The subframe then needs to be chopped down to accommodate for the larger pumpkin. The only thing left for me to do it box in the subframe and weld in the mounts and mustache bar I fabricated.
