CAM280
- 49
- 11
- Oct 6, 2019
BRISBANE,
Australia
G'day from down under...
Ive been doing a 6bolt swap and went to install the 2g cas and realised I have a 1g intake cam. Should I take that cam out and replace it with the intake cam that has the screw hole in the end or just install the 1g cas and wire it to the 2g cas connector. I already deleted the BS and installed a Kiggly crank sensor so i'm just wondering if I need to just work out which wires go where and would I need to invert the ecu as well?
So theres 4 wires in the 1g cas and only 3 wires in the 2g cas connector, I have the green 1g cas and the wires from the 1g cas connector are white, black, red, black. the first two wires seem thinner than the last two wires.
