You're not a true DSMer unless.......????
1990TSIAWDTALON
Moderator
11,537
8,206
Nov 14, 2013
Independence, Kansas
Lets have some fun while most people are are home! :p
Fill in the blank with your favorite saying!!!!
I can't wait to see what this brings out ROFL
"___________________________________"
Just add to the post, lets see how many funny (or TRUE) things we think of. :thumb:
This already has a good smile on my face with more to come!
Y'all know mine...
You're not a true DSMer......
unless you have at least TWO of EVERYTHING!!! :ohdamn:
(and dammit, I need another wastegate and guess what.....I'm not a TRUE DSMer :( )
Oh yeh, gotta chase those things or what fun is it.....:idontknow:
You're not a true DSM'er unless.... you have bear hugged a trans siting on your chest under the car and said, "I am too old for this S**T".
I didn't say I was too old. But the next day my back thought so. :confused:
I did that at 15, but it was an Isuzu.... and sucked. Still waiting to dive into this one
You're not a true DSMer unless if your dsm has been on jack stands for 4 weeks.....
-you have a garage/shop that doesn't fit your DSM's, because its full of you DSM parts.
-you blow your entire paycheck on shti you don't need.
-You've resealed a valve cover umpteen times...and it still leaks.
-You've searched DSM, Eclipse, Talon, Laser, Galant, turbo, Evo and 5x114.3 in your Craigslist search bar, daily.
My favorites from A-Z (pick your favorite one or how many do you know?):
A) Broken at least 2 door handles.
B) Gotten lower headlight assembly bolt in/out without removing bumper.
C) Figured out how to remove the 2g center timing cover without cracking it by only removing 2 of the 3 drivers side engine mount bolts (so 3rd holds engine up).
D) Rebuild tranny 3 times because always getting a worn shift fork causing shifter popouts before finally figuring out it's due to the skateboard bearing mod in tranny end shift cables.
E) Figuring out what the "generator relay" is for and why it always is destroyed in our cars.
F) That the starter relay actually disables the starter in most versions.
G) Knowing where the clutch disable switch really is.
H) Knowing where the stock Infinity radio head unit ground really is.
I) That forgetting the lower backwards facing tranny/engine bolt contributes to crankwalk.
J) Finding out the result the hard way of putting the fan pulley halves on backwards.
K) The result of forgetting the tranny backup switch washer or using wrong thickness.
L) Figuring out that all the extremely complicated timing belt tension procedure can be replaced with just making the grenade pin to slide easily in the hole.
M) When you break your 18" breaker bar trying to get the axle nut loose.
N) That the clutch fork swivel point wears down, not the pivot ball.
O) That to loosen the tranny gear stack, placing it in 2 gears at once works way better than stuffing all your rags or coins between gears.
P) That unplugging the front O2 sensor harness connector is unfathomable.
Q) The fun of getting the 2g VSS connector (and its clip, ha, ha) on.
R) That the fuel pump ground connection is really under the drivers seat.
S) Your cursing of not buying the EuroExport spring compressor tool when installing valve stem seals.
T) Finding out it takes 6 revs to line up all the timing marks after you put the spark plugs back in.
U) Figuring out how to get the Room Lamp fuse out.
V) Putting the B belt tensioner pulley lip on backwards wearing down the belt edge.
W) You install the alt belt before the PS belt.
X) You break your finger trying to get the stock air box clip on - you know the one.
Y) You run out of glue constantly trying to fix the broken top timing belt cover bolt hole - you know the one.
Z) And the best one: That after both tearing the ball joint boots during ball joint disconnect and removing the axle nuts to get the drive axles out for a 2g tranny removal, you discover my post showing you didn't need to disconnect the ball joints or axle nuts at all.
From A-Z - pick one:
B) Gotten lower headlight assembly bolt in without removing bumper.
C) Figured out how to remove 2g center timing cover without cracking by only removing 2 of the 3 drivers side engine mount bolts.
D) Rebuild tranny 3 times over 10 years because of worn 3-4 shift fork causing shifter popouts before finally figuring out it's due to the skateboard bearing mod in tranny end shift cables.
Q) The fun of getting the 2g VSS connector on.
Z) That after destroying ball joint boots during removal and removing the axle nuts to get the drive axles out for tranny removal, you find out you didn't need to disconnect the ball joints or axle nuts at all.
How did you get the lower headlight bolt out without pulling the bumper?
