TheFlashDSM
Supporting Member
- 1,082
- 312
- Feb 18, 2010
stony brook,
New_York
99 eclipse gsx
i have a 10 gal in the spare tire well.
what ohm's is the factory fuel level unit, so i can buy an aftermarket fuel level unit one for my fuel cell.
what are the wires i should use? back of cluster or straight off the harness by the oem fuel pump plug/harness
i starter this thread due to lack of information i could find on the ohms of the oem fuel level unit, as well as the wiring.
if anybody knows where to find this i will be more then happy to read and figure it out myself.
but if you know simply, ex 0-50ohm fuel level unit. and wire (color) off the harness/cluster you would be the best
build thread >>>> https://www.dsmtuners.com/threads/my-2g-dsm-second-build-this-ones-going-smoother.499369/
