rabenne
- 1,803
- 836
- Apr 21, 2006
Racine,
Wisconsin
All good just never seen that issue before. Test it at the outlet?
You could observe bov behavior if nothing else. My crushed 1g BOV would start opening at 25-27 psi. That's when I went to a turbosmart with easily adjustable spring preload. You could shim the spring in your tial, or use a stiffer spring, if its creeping open too early.
