Orca - 11 sec street rippa
I need tires to for my evo 8s.
I didn't want to shell out $400 but one of my tires is worn more than the others and probably not good for the drive train.
The final piece for ethanol. Big daddy hellcat 525 w check valve.
Big boy stuff right here
:mrt::)
She’s a beauty! Definently my next pump:rocks:
It’s a little awkward to install since the rubber spacer on the bottom isn’t a perfect fit and they give you a useless plastic tube that won’t work on dsm. The zip tie and hose helps it stay in place.
Zip Ties ftw LOL, I’m curious if this pump is quiet like the 450 I currently have. Forgive me I haven’t read thru the whole build thread yet but what are your power goals?
Nice install Tony! Did you have to cut off the bell on the fuel pickup tube or was it already done? That is EXACTLY how mine looks but I have hose clamps and a insulator for any noise, which is really nothing in my car either.
Good job for sure!!!
Hoping she is all you ever need (unless you go to some outrageous setup)
Marty
Marty
Yes I cut it off last time I was in there. Pretty sure I’ll be set as long as I have the car. I do plan on building the tired bottom end somewhere down the road. Then maybe shoot for 600 :idontknow:
Used the topline crank seal that came in the complete gasket kit and it’s junk. Didn’t even last a year < 3,000 miles. Picked up an oem seal from stm. Never using anything but oem seals.
Found my stash of slips from the drag strip from back in the day. I had 15 runs on the first day of keeping record at Raceway Park in NJ, back in 1998. Unheard of in the later years.
Out of gloves, Covid! :toobad: Have to ration them but I’m ok with that. First responders need them way more than I do. Ugh hate working without gloves.
Had a small strip left. Might as well put her to use. BUT that block though :barf: Soon...soon.
