AWD-Tony
- 6,801
- 3,735
- Sep 11, 2017
Cincinnati,
Ohio
I recently installed a backup camera that came with my head unit. The camera is activated by the reverse light so it's wired to 12v & ground wires to reverse bulbs. Worked fine until I switched to LED reverse bulbs. It comes on fuzzy like an old black and white tv. Electrical wizards, If I install a 4 pin relay and switch the power (same as fuel pump rewire 12v) and ground, will this fix the fuzziness?
