White flour1gawd
- 69
- 10
- May 22, 2016
minneapolis,
Minnesota
Is there any write ups on changing transfer gears to straight cut?
the only thing offered on a dsm in a straight cut transfer gear is for the autos. theres no how to on this. you either get brave and wing it or send it to a reputable trans builder to have them do it.@ThunderChild Maybe. Questions not very clear. His profile shows manual.
There are simple to install..... if you do your own engine work , these can be installed by a amateurIm swapping over to auto from manual. Thanks for the answers guys
Is there a place online to search for these gear sets?There are simple to install..... if you do your own engine work , these can be installed by a amateur
They need to be ordered through jeff bush , when your ready to purchase them I can send you in the right directionIs there a place online to search for these gear sets?
Sweet, Definitely be contacting you in the future. ThanksThey need to be ordered through jeff bush , when your ready to purchase them I can send you in the right direction
