Clappedout_GSX NoCrst
Ordered all new suspension components for the front end this week. Hoping to get some time to install everything next week.
New Parts
Upper Control arms (Moog)
Front Knuckles (OEM)
Front Hub Assemblies (Moog)
Lower Lateral Arms (OEM)
Front Compression Arms (OEM)
New inner/Outer Tie Rod Ends (Moog)
Cv Axle Shafts (aftermarket as place holders while I reboot and grease my OEM Axles)
Also ordered an EVO X front License Plate Bracket to get a front plate installed.
Looking forward to having some pictures next week and getting some updates done.
Happy day for me. Scored a Megan Racing 3" Turbo Back for $300 w/gaskets to install from a local guy. Got it all installed and the wideband in. Just need to finish wiring up the wideband and we'll be good to go! Very pleased with the sound of the exhaust and fitment! Also got the Evo X License plate bracket installed thanks to https://www.dsmtuners.com/threads/evo-x-license-plate-bracket-write-up-2g.460943/
Decided to do a little project yesterday while stripping the interior to add sound deadening (Going with an off brand Dynamat called Kilmat). My headliner had been driving me crazy forever with sagging in the front. I believe this car may have had a smoker in at some point. Pulled the Headliner and using some 3M Adhesive reattached the existing headliner properly and heated it to cure the adhesive. I then proceeded to add a little personal touch and refinish the headliner with a new pattern/material. In total this project cost me about $35.00 and 2 and 1/2 hours of my time. Super Stoked with how it turned out and looking forward to seeing how well it holds up to heat and temperature change!
Had a little free time over the weekend and got some more work done on the car. Went ahead and installed a new carpet kit, sound deadening and new speakers all around. Made a world of difference in comfort for the vehicle! Sure it added some weight, but I'm willing to add weight to reduce road noise and approve acoustics.
Installed a Forced Performance manifold and 14b with a 7cm housing this weekend and what a world of difference that made! Very pleased with the increase via the butt dyno and exhaust note. Gave the car a nice mean growl under heavy acceleration!
