HIGHPSI4
20+ Year Contributor
- 809
- 10
- May 11, 2003
Vale,
North_Carolina
You don't understand. Hood vents work the same way that airplanes fly. It will suck air OUT of the engine bay.
What you seem to fail to realize is that hood vents, unless engineered, do not work to cool the engine bay. The same principle that allows airplanes to fly will push air from the hood into the engine bay and thus reduce the volume of air moving through the radiator which will make the engine over heat.
