Broken
So I have a question. I found a used head. Has 272 cams. Comes with new valves and lifters. He says it’s a 7 bolt head but had it on a 6 bolt. So has it been modified to run on 6 bolt? Can it be used on a 7 bolt again? I just figured I’d ask before I purchase it. Any advice would greatly be appreciated
I already answered your question in a different forum but why are you changing the head? What is wrong with the one you have?
I have the block at the machine shop getting bored out. Previous owner fried the rings. The head so far I need new lifters I want to change the cams. I just seen it and figured it would be nice to have another. I figured the cams alone are worth 400. I’m going drop my head off when I pick up the block. Then I’ll go from there. I noticed the valves are not closing all the way. I’ll post a pic once I get off work
