2G Eclipse Brake and Clutch Pedal Return Springs Hook Onto What?
n7k1
31
23
Sep 7, 2019
Coquitlam, BC_Canada
I took my pedal assemblies off my 98 Eclipse to remove the rust and repaint them. However, I can't remember where the clutch and brake pedal return springs connect to? Can someone tell me where to connect them to or better yet take a picture?
Thanks.
From the serevice manually. Brake is a little simplier than the clutch pedal.
Clutch-
Brake-
Thanks. I really appreciate it. But, where does the Clutch Pedal Return Spring (#3) and the Brake Pedal Return Spring (#1) connect to under the dashboard?
Here's a pic to help you out. It's not the best, but there's a reason I'm not a photographer. Lol. Hope this helps you.
I already took these so had to add them
Your pictures are much better anyway. I just couldn't seem to find the perfect angle while the car was on the lift. I thought it would have made it easier. I guess I'm getting too old. Lol
