gsxitement
20+ Year Contributor
- 1,898
- 1,682
- Dec 9, 2002
DOBBS FERRY,
New_York
I've been doing a wiring delete on my track only time trial car. Got the car fired up yesterday. Runs ok. My problem is link won't connect. At my DLC, I have 12v on pin 16, 5v on pin 1, pins 4 and 5 show good ground, and I've got good continuity through the pink data wire on pin 7 to the ECU. I get a "port refused to accept required bitrate" message. Also, my little pocket scanner won't connect either. I can't see the ECU being bad cause it just sat in my house while I did this work. I will add, that everything is custom. My own fusebox, my own relays. The MFI relay and fuel pump relay are controlled by switches on the dash panel. Any insight or recommendations would be appreciated. Thanks again.
