Difference between these two transmissions
AWD-Tony
6,801
3,735
Sep 11, 2017
Cincinnati, Ohio
I dont have caps or ASA anymore. There lots of differences. Also not sure that list is complete. 91 to 94 are not the same. Different sized hubs. Single vs double cone synchros. Gvr4 has different first gear
Pretty sure the Gvr4's are a bit lighter duty if I have heard about them correctly.
Piggybacking on this, but is there a significance between the "K" as the first letter before the "W5M" on some trans? Mine's a '97 and also has a K at the start of the code.
This is copy and pasted from an older thread:
DSM AWD (3.083)
2000rpm =14 mph
3000rpm =20 mph
4000rpm =27 mph
5000rpm =34 mph
6000rpm =41 mph
7000rpm =48 mph
8000rpm =54 mph
9000rpm =61 mph
10000rpm =68 mph
Galant VR-4 (2.846) (8.5% taller)
2000rpm =15 mph
3000rpm =22 mph
4000rpm =29 mph
5000rpm =37 mph
6000rpm =44 mph
7000rpm =51 mph
8000rpm =59 mph
9000rpm =66 mph
10000rpm =74 mph
My tranny-shep stage 3 with welded center diff
-Output shaft - I can’t turn it by hand
-Input shaft - I can turn it but it’s much harder than the galant trans
Galant trans
-I can turn both shaft by hand fairly easily.
Both are in neutral
Is this because of the welded diff or something is wrong?
Here's a little info from the tranny FSM about the marking codes that may help get you started.
  • Eclipse-Transmission Manual.pdf
I am not sure about USDM Galant transmissions but if USDM NQ Galant VR4 transmission is the same as JDM NQ, it has the same ratios as DSM. The Galant VR4 transmission with a "WQ" code is the one that has the same ratios as taller EVO1 ratios.
Galant trans
Both are in neutral
I'm going to say that something is wrong if you cant turn those shafts, the welded diff for example has nothing to do with turning the input shaft in neutral.
Hey Tony, ever think about the difference in the Front dif compaired to your Non-Galant rear dif ratios?? I haven't but want to make sure you don't trash something here. Just double check.
Definitely something wrong with this one.
Shit. I wasn’t thinking about that. I’ll have to look into this. Just finished the install. Need to add fluid and drive it but this concerns me.
I pray it’s the same. I’ll look into it tomorrow.
Thanks all for the input.
If you have the wrong rear ratio you will know, the car wont want to move and when it does it will screech the rear tires in gravel or anything soft.
I just copy-paste these infos here from my old computer.
I made this for myself a long time ago to organize the differences and I haven't proofread since. So there could be some typos or missed some, excuse me if I did.
JDM Galant VR4 (Code: PH, NP, NQ)
1st : 12 / 37 3.083
2nd : 19 / 32 1.684
3rd : 26 / 29 1.115
4th : 30 / 25 0.833
5th : 33 / 22 0.666
R : 3.166
Front Diff Ring Gear : 58 teeth
T-Case : 1.09
Rear Diff : 3.545
JDM Galant VR4 (Code: WP, WQ)
1st : 14 / 36 2.571
2nd : 20 / 32 1.600
3rd : 25 / 29 1.160
4th : 29 / 25 0.862
5th : 34 / 21 0.617
R : 3.166
Front Diff Ring Gear : 64 teeth
T-Case : 1.09
Rear Diff : 3.909
EVO 1
1st : 14 / 36 2.571
2nd : 20 / 32 1.600
3rd : 25 / 29 1.160
4th : 29 / 25 0.862
5th : 34 / 21 0.617
R : 3.166
T-Case : 1.09
Rear Diff : 3.909
EVO 2
1st : 12 / 33 2.750
2nd : 19 / 32 1.684
3rd : 25 / 29 1.160
4th : 29 / 25 0.862
5th : 34 / 21 0.617
R : 3.166
T-Case : 1.09
Rear Diff : 3.909
EVO 3
1st : 12 / 33 2.750
2nd : 19 / 32 1.684
3rd : 25 / 29 1.160
4th : 29 / 25 0.862
5th : 34 / 21 0.617
R : 3.166
Front Diff Ring Gear : 63 teeth
T-Case : 1.074
Rear Diff : 3.909
Will I notice it on pavement?
As long as the the tooth count on the the final drive ring gear is the same as what you had your ok......most likely 58t
The trans is installed so IDK. I spoke to guy that sold me the trans, and he had it in his 1g. All point to this trans being compatible. I'l put fluid in and take it for a ride after work.
Would the speedo be the same between the trans if the two had different gear ratios?
You can use your 1g speedo driven gear. Some other car (maybe some limited version of galant vr4 too) and EVO 2/3 have a different tooth count on it. Between your two transmissions, I am almost sure that they both use the same speedo driven gear.
The FSM excerpt says the speedo gear ratios are slightly different. NQBM = 30/36 NPXV = 29/36. Both should have the same gear ratios, transfer & final drive though. My guess is because of different tires sizes from the factory with the different original platforms.
