2G Where to find this replacement vacuum hose?
Matt_sagun
2
Oct 20, 2019
bristow, Virginia
I was replacing my fuel filter on my 99 GST and had to move some stuff out of the way and broke this vacuum hose and need to replace it. think its one one of the check valves that spider out in to like 4 different vacuum hoses.
It's located behind/under the battery. Not sure what to look up or search for to get a replacement. Pics attached. Thanks!
Normally there should be a vapor canister in that area did you remove it perhaps the previous owner deleted it... well if that is the case you just have to loop it back using parts store fuel vapor hose and adapt the bigger size down to the smaller size or get a good used vapor canister i'm pretty sure that is what those lines go.
I had no idea that something was missing in that space. Can someone send a picture of what I'm missing? THanks!
Sum Beech....is this what I am missing?
Eh, just buy some hose that will fit from the auto-parts store and send it...
I can sell you a charcoal canister or a vacuum canister, or whatever these things are called. I got all that crap laying in my garage if you need any.
Interested. Let me know what you want for it :)
