Kyky819
5+ Year Contributor
- 53
- 7
- Aug 31, 2018
Otis orchards,
Washington
Hey everyone I have a 95 talon that lost the blinkers about a year ago. So far I’ve replaced the 3 prong relay behind the radio, checked both fuses under dash and in the engine compartment and their good, checked for power at the relay, fuse box and sockets and replaced bulbs. For some reason I’m getting around 50v at the rear sockets? I verified the turn signal switch is working and clean of corrosion along with the hazard switch. I’m not the best at electrical but I’ve checked everything I know to check along with reading on the forums. And help is appreciated because I’m at a loss.. also the blinker relay doesn’t click. Thank you
