96eclipseGST
Hell yeah sounds good man I just like to meet up and look at other peoples projects and shit. What all u have to do to it? I still have to do some little thing to make mine worry free but yeah
Got in the boost gauge today installing it to the dimmer knob wasn’t easy. But finally got it. Kept hooking it up and the ground was just grounded to bolt but I needed to hook both ground and positive to the knob... who figured.. LOL
Got 2 of 3 gauges filled looks alright even took the little bulbs out of back of dash gauges and replaced with blue led bulbs and even wired up a few led bulbs streight to the other back. And panted the black cover blue and gold. Don’t know if u can tell. but I like it and it works, it’s the little things man.. cant wait to check it out at night. Get pic soon.
Was gonna re paint the middle of the tail lights a gloss black to match with the car but started sanding it and BOOM. Found it was a after market and so I striped it all the way down heated the rubber and pulled it apart and paint it to match the black with gold. Thinking about adding some leds to it to light it up a bit. What do y’all think?
I say no to led
Hell yeah I didn’t realy think it would look good. Me personally I like the painted to match the car look but I don’t wanna hide something I can make Unique.
Dressed up the engine alittle bit. Seen that there was a vacuum line comeing out of the fire wall on the passenger side above the battery. U guys know where it goes?
Add the photo here
Add the photo here
I tryed can’t real get good pic. It has a rubber boot around it going into the fire wall right to the left side of the battery and it runs underneath the batter where that big air tank and stuff is down there.
So it has nuthin to do with the running of the motor? Should it b hooked up to a vacuum line?
IDK which one it is. If it's for ac drain, it lays on the sub frame off the firewall iirc, and doesn't go to anything.
