langelg6
- 52
- 13
- Nov 4, 2019
Hammond,
Indiana
my car is a 1995 eagle talon esi.
lately ive been having flooding problems for the car to where it would cut off mid drive and flood on the spot. but today after leaving my gfs house I got in and started right up but the car shut off after a minute of idling. it didn't make any funny engine noises that I was aware of it would just turn off as if I turned the key to off, and then the car would fire right up, run for a few seconds and die almost instantly.
I started it up and ran it 9 more times and it shut off 9 more times before I gave up and came to write this... its 19 degrees out, 10pm at night and the car is at my gfs who doesn't have any form of diagnostic tools so I can't really check "the obvious stuff til tomorrow"
living in northwest indiana you will experience 4 seasons in a week. its gonna be 50 degrees out tomorrow and ill see what happens
also when car was running I could rev the piss out of it to 7k rpm but it would cut off a few seconds after letting go of the throttle
just tried to start again and same issues but I tried to listen for any funny noises.. only thing I would notice is some kind mechanical whirring coming from the drivers side. its makes a similiar sound when you turn key to accessories on 1 turn before start
ok so tried starting again, and tried to pay attention to any little detail. from what I realized it starts instantly and revs all the way to 7k rpm easily but will cut off approximately after 10 seconds of running. is there anything I can check to give you guys an idea of what could be the problem
