1G ABS warning light
Topcarparts
31
Aug 27, 2019
Manila, Asia
I have an ABS warning light on my cluster gauge.
Question is does this ABS warning light affect my transmission resulting into limp mode?
On my 1g I have this 3 problems
#1. ABS warning light
#2. Limp mode (stock on 3rd gear) after few minutes of driving.
#3. Cruise control not working (but the control switch is working) still no cruise light on cluster gauge.
So far I've checked the bulb but its good.
Need help on this guys.
TIA...
Is your speedometer working? you could have a cluster failure where the speedometer is not outputting a speed to the TCU. What codes do you have? Finding that out will enable me to give you a better idea where to look, if you don't know how to pull transmission codes, search how to do that.
I would venture to say Matt is correct, the VSS is not working or is not sending the correct info to the ECU and TCU (hince LIMP mode).
Is your speedometer working? you could have a cluster failure where the speedometer is not outputting a speed to the tcu. What codes do you have? finding that out will enable me to give you a better idea where to look, if you dont know how to pull transmission codes, search how to do that.
My speedometer is working sir..but sometimes i think not acurate..if i scan this..does the transmission code will show up?
I will try this sir and post result..tnx much
But i know only the pin on ecu and abs pin on the connector sir.. i dont know which pin is for transmission
