- Thread starter
- #26
pieceofcloth
Supporting Member
- 476
- 436
- Oct 6, 2019
Houston,
Texas
Theres this flat face plate that is on top now, you can easily reach in there and pull it out. It is not attached to anything. Then you'll see that gold color thing in there with a hole in it. In the center is another bearing. That little hole is an alignment spot which is placed on this little shaft/stub that sticks out. you can't miss it or place it wrong unless you are wanting too. The center bearing slides right out because you can see that gold piece has a crest shape to it. remember to match your parts
