1G turbo from a flood, repairable?
pieceofcloth
Supporting Member
476
436
Oct 6, 2019
Houston, Texas
I picked up a vehicle this past weekend that was in a flood. I'm not sure how high the water got. Are turbos generally repairable? There is minor play and it spins smoothly. Is anyone familiar with rebuilding turbos? Can any of you recognize this piece? Thank you in advance.
Was there water in the oil? The turbo may be fine the way it is. Clean out the compressor housing maybe. The oil system is sealed for the most part unless water got in the oil.
Was their water in the oil? The turbo may be fine the way it is. Clean out the compressor housing maybe. The oil system is sealed for the most part unless water got in the oil.
I just pulled the vehicle home Saturday & gutted it today. I'm cleaning the garage out tomorrow so I can bring the vehicle inside and strip down the motor/accessories. When I turned it by hand, I was expecting a rough or sandpaper feel because of the situation the vehicle was in, but it turned very smoothly. I only spun it lightly, & once and with no power behind it, because I feel you shouldn't just go around spinning it like crazy. I just wanted to make sure it wasn't seized. I read up and seen how people rebuild turbos. It looks fairly simple, except I can't balance the shaft myself. I can only replace whatever seals or parts necessary.
Squirt some oil in the oil feed for good measure and spin it so it has fresh lube. It may be just fine. Looks like a knockoff Holset turbo to me. I'd run it and if it gave me problems, I'd pull it and do a rebuild or send it to a reputable rebuilder.
Sorry about the delayed update. I pulled the motor & dissembled everything. I am able to salvage the build so I've been focused on getting that going. Here are three pics of the turbo off the vehicle. It looks like a BullsEye Brand model S362. Anyone with personal experience ? I'm going to take it apart & see how everything looks within. Thank you guys for all
yalls input/help :hellyeah:
According to my research, that's a very pricey turbo. I'd say it's worth rebuilding/using!
If Justin, @JusMX141, were on here, he would verify that it is a Borg Warner S362. I don't know if they have rebuild "kits" or have to go back to the manufacturer but he would know. I haven't seen any posts from him in quite a while, but he is a turbo specialist
If Justin, @JusMX141, were on here, he would verify that it is a Borg Warner S362. I don't know if they have rebuild "kits" or have to go back to the manufacturer but he would know. I haven't seen any posts from him a quite a while, but he is a turbo specialist
I'll send him a message & will email the company to see what they have to offer. I used a light brass bristle on this harbor freight hand held dremel tool. I didn't apply pressure, I just let the stuff fling off. And on the blades I used some qtips to wipe the surface but everything seemed to smooth out. I was suggested to pour some oil within the feed but I'm not sure which type I should throw in there. I'd love to send it in, but I'm not looking forward to a 400$+ ticket. Especially if i'm able to replace the seals myself. first 2 are after pics - last 2 pics are before :idontknow: : thanks again :hellyeah:
The S362 stand for 62 mm. It is part of the S series. It has a cast compressor wheel, and can support up to 650 hp. It has a 4 inch inlet.
This is the info I was able to gather about it.
mann, thank you so much for that. I appreciate you bro, foreal :hellyeah:
with a quick search, i found a couple of folks selling kits. I think i'll go ahead and order me one. my mind is so tied up with the motor build, i didn't even think about a rebuild kit for this turbine. mann i feel dumb LOL
Just squirt a bit of oil into that elbow fitting to lube the journals. Or on the opposite side (bottom) is the drain and you can put a tad in there. I mainly wanted you to get just a little lube on the brass journals :)
Let gravity do its thing.
You basically have THIS...maybe a little better :shhh:
My finger is pointing at the oil feed.
oil has been squirted : Is that going in the Saturn? :D Thanks for all your help Marty, you the man
Nah, I'll throw a Super 99 on it..............ROFL
Oh I was just teasin ya. My Saturn is a true daily driver and definitely under powered. I have heard of a fellow in Wichita that was throwing a 150 shot of NO2 to one and it lasted 2 years with that. The bottom ends on the Saturn 2.0 is very cool with full floating pistons and a nice big main girdle from the factory. I was amazed when I tore it down to rebuild it at 260k. Has 283k on it now, and is very reliable. I drove the stock GSX to work today, just so I could pass cars on the freeway LOL.
I ordered a kit online a few days ago & it came in early. I decided to tear this mofo down. Here are a few shots of what to expect from a borg warner s362 bullseye turbo : I was just taking photos for reference, not a tutorial or guide but it will definitely help any of yall who are in need. All turbos should be the same with a little difference here and there : I can't give it a difficulty level because I'll take on any task & am not afraid. This job does requires patience, attention to detail, feel, sight, common knowledge, & being mechanically inclined. Anyways.. here are some photos
** The shaft locknut is reverse thread so turning the nut clockwise will release. I used a 14mm on the nut & a 17mm spline socket on the exhaust side (12point socket). I used a breaker bar, 3/8 socket wrench, small pair of needle nose pliers, a set of retaining ring pliers, rubber mallet, lubricating oil, and my phone for the camera.
i removed the turbine wheel, and pressed the shaft gently on the floor to pop it out of the bearing system.
I wiped all that bs off those parts with a rag, and used that 9.99 harbor freight dremel tool with like 100 accessories to clean the surface and whatever other hard to reach spots.
there is a retaining clip which you can see from the photos above that holds that gold looking bearing within. Its a retainer clip, bearing, then another retaining clip on this side..so once you take the top one off, you can turn the unit upside down and it'll slide right out. You'll then look inside and see the other clip waiting there for you to remove it. The bearing sits on it.
My pieces were stuck within because the vehicle that this came from was fully submerged back in 2016 & this is its first sight of light. I used my needle nose pliers which I got from harbor freight today for like 1.39$ and carefully aimed it to that round piece so i could pop it out. I MADE SURE I wasn't hitting any other part other than what I was aiming for.(which is the piece I'm taking out). I used my rubber mallet and barely touched the pliers to budge it. I wasn't trying to hammer a nail.
Here is the piece I was aiming for & it removed. You can see it is two pieces. There is that center circle bearing and the outer larger. The center piece will pop out with some pressure. You don't need any tools to remove, just use your thumb strength.
here is a photo the newer one from the kit. You will see the two pieces which I place together. The center smaller one has a clip/ring that needs to be put around it which is included in the kit. Basically when you remove something, look at it & match with the supplies that came with your kit. Look at all the details from the lengths, width, are the clips face forward or flat side down, etc..I didn't want to use motor oil, so I just used some lubricating out that I use for my shotguns. It should be fine. lubes all of the assembly, get dirty
