2G Cam Card Help
Mattchew
Jul 19, 2015
Galena, Missouri
Can anybody tell me what's wrong with my cam card. I think they sent me the wrong one. When you run the numbers through a centerline calculator they don't add up.
What specifically dosen't add up? Only numbers on the cam card that would be pertinent is the duration. I get 23+180+67=270. These number are the same for both intake & exhaust. ???
Sorry I should of been more specific. When I try to degree my cams I can't ever get 23 @ .050 it's more like 2 degrees and I don't have enough adjustment on my adjustable cam gears to make up the difference. It's the same for 67 it's more like 28 degrees @ .050. Wouldn't the centerline be different than 109
23+67+180=270÷2=135 centerline not 109?
I don't think your cam card is showing duration @ .05. It has strikeouts under this column. I think the 270° is advertised duration. I believe 109° is Lobe Center, simply the distance between the peak opening points on the Intake and Exhaust lobes.
So how am I suppose to degree the cams based off the cam card?
Watch this video from the Master, Jafro.
