byAzon
- 43
- 3
- Jul 27, 2019
Cheyenne,
Wyoming
Mod list: DSMLink v3, 1220cc injectors, speed density (Mitsubishi style), after market fuel pressure regulator, gt35r turbo, tubular manifold, FMIC, Walbro 450 pump.
Got the car in pieces and finally put it all back together. I can get the car to fire up like normal and it will hold RPMs but every time it dips below 1k RPM it just stalls.
I did a boost leak test and everything fine no leaks. I got two good data logs that I’m gonna try to post. I also have all the correct setting for speed density. I’m getting a new ISC tomorrow and TPS is adjusted to .63 bolts and cable linkage is adjusted. The only way I can keep the car alive is to blimp the throttle if I try to hold the pedal it will stall out. Any ideas anything helps
