4G63 98 mtx NT spyder trans cover
Lifesave
7
Aug 13, 2019
Estero, Florida
Help please
Found my tranny leaking on my 98 spyder, discovered this casing cracker and punched out
This is a new acquisition and needs this part before I fix the misfire
Previous owner mentioned 5th gear issues hmnnn
Anybody know the correct name and or part number?
Or have one?
Anything appreciated guys
Thanks
Pics below
I wouldn't throw it in the trash. You MAY have to have it welded up. I did a search for F5M33 end covers and came up with a big ZERO. It is a common issue for the end nuts to come loose and off as @motomattx said. I have had that issue myself but the nut hadn't come off yet.
Yes the nut came loose and dug into the cover, I am not sure if its a 63 or 64 ?
Its a 98 and new to me. So it has a hairline Crack as well, I guess it could be welded carefully because of the gear it seems to retain. If welded, do you use locktite or a cotter pin deal?
Since it's a Spyder you have the 4g64. It is similar to the 4g63 though. For future reference, the 4g64 is a 2.4 and the 4g63 is a 2.0. Only the ones from out of country have an N/A 4g63. :thumb:
