2G Weird Problem With 4th Gear
Steve_Is_Wumbo
Supporting Member
4
Nov 5, 2019
Bourbonnais, Illinois
I'm new so I'm sorry if I do anything wrong.
I got a '97 GST a couple of weeks ago. It was a no start and had been sitting for a few weeks. I got the car running and runs ok, but my car doesn't like 4th gear. It drives fine 1st through 3rd but when I shift to 4th the car shakes and dies. Then each time I try to start the car after, it won't idle. It starts then shuts off. I can keep it running by giving it gas. If I let it sit for like 20 minutes it runs again.
I'm not sure if I just need a new trans or something else. I'm just unsure what's wrong.
Welcome to the forum! No, you didn't do anything wrong, but it will be much faster for you to get answers to your questions if you complete the DSM Profile section for your car. That way we will know, for example, if this is a manual, or automatic, transmission?
It sounds like you have a transmission that is failing, causing a large amount of friction when placing certain parts under an actual load, you could drain the fluid to confirm if there is metal shavings in the oil.
Thank you both for help
I'll drain and change the oil when I get paid.
What rpms are your shifting into 4th? Skip to 5th at a decent speed to accommodate the gear and see if you have similar results.
I'm shifting around 5k, and I'll try skipping the gear tomorrow.
