EVLGSX
5+ Year Contributor
- 655
- 253
- Dec 7, 2017
Wallingford,
Connecticut
do you have to upload pics one at a time or can you dump a whole file in one shot somehow?
You should be able to upload them all but I do have trouble sometimes and think it’s because the file is too large. You can upload one at a time. That way you’ll know which one is too large
Nice build evl! That tcase probably costs an arm and a leg. Is that your crx? Pretty clean and they’ll be going up in value as long as it’s not a rust bucket.
Something happened to your pics. I was able to see them yesterday but not today.
I've just read through your short journal, and so far you've got my respect. But...Ive been putting off the state emissions test for almost 2 full years now. My registration expires on the 27th so Ive got that many days to get it set up to pass. Ive got everything I need to do it but its just such a lame thing to do to the car. Especially when Im as happy as I am with how its performing.
I will have to-
-undo EGR delete
-undo EVAP Delete
-Pull evo3 IM
- install Stock IM
-hook MDP sensor back to its channel which has been taken to log fuel pressure
-install FP solenoid/ EVAP solenoid/ whatever that 3rd solenoid is (forgot what its for ATM)
- install a cat back setup with a cat (which I had to weld up the other night so it will bolt to my 3'' downpipe just so things dont get too crazy as far as what I have to do exhaust-wise)
-hook the rear O2 sensor back up to its channel which has been taken for the wideband
-Install the stock MAF / swap back from SD (I dont think I technically have to do this, so I might not)
then just make the necessary changes in ecmlink...........I think thats everything.
None of this is fun or cool, and I am going to hate every second of it.
However, I have a pretty cool part on the way that I'm pretty pumped about, and am really looking forward to trying it out....... so ambition levels are way up. All the lame changes will be undone quickly after and I am also thrilled by the fact that this is the last time I will ever have to do this with this car.
^Just reading that list made me cringe and gag. It really does suck how you did that much work to the car, and now you have to undo it for testing purposes, and then do it AGAIN assuming they give the thumbs up.
That one post leaves me with two words: MOVE SOUTH I've never had to do emissions testing with my car, nor have my friends with theirs. If they pass from the factory, then no one cares. But seriously, glad to hear that you won't have these problems anymore.
Man that blows. I think classic plates exempts you from state inspection and/or just emissions testing. That might vary from state to state and you’re only a few years away. Make sure you drive it to get most of you monitors complete so you don’t waste your time.
