Sephent
- 61
- 2
- Feb 18, 2016
Medford,
Oregon
I noticed that sometimes when I hit the turn signal or go to put on the brights, my dash lights (all inside lights actually) and tail lights flick off.. If I wiggle the multifunction switch around, they flicker off and on, and if I hold it to turn on the brights, without pulling it all the way for the brights to stay on without me holding the switch, all the dash and tail lights go out until I either let go of the switch or let it click to keep the brights on...
Iv read that issues with the dash and tail lights has something to do with the dimmer switch going out... Would that be the case here? I need to pull the plastics off around the multifunction switch to see if anything is rubbing weird... All fuses seem good other than that. Anything specific I should look for? The dimmer switch works fine itself (dims the dash lights when I turn the knob). Thanks in advance.
