AWD-Tony
- 6,801
- 3,735
- Sep 11, 2017
Cincinnati,
Ohio
I'm going to start tinkering with the boost error correction function in link as my boost fluctuates slightly (up and down) +/- 2psi at the top of my pull. I've read their wiki page several times.
http://dsmlink.com/wiki/bcssetup#approach_1just_disable_error_correction
"When you do this with “good” data, you'll find a table similar to the following:"
Why is this a good table? Don't you want boost to hold steady until redline? I have a 68hta V2 w Tial MVR using both top and bottom ports.
Thanks
Tony
Thanks
Tony
