Sam's GSX
5+ Year Contributor
- 395
- 54
- Jun 10, 2018
Hohenwald,
Tennessee
Ok first i'll ask my question, on this log my wideband reading goes straight, does that just mean i need a new sensor? the car didn't feel like it was messing up at all, in fact this is the best pull I've ever had.
a couple weeks ago i switched from the 500cc nozzle to the 1000, trying to get rid of that last little bit of knock, i just ended up getting a bit more knock (1.4 max instead of .7 Max) in my mind it should have helped (I still don't understand how it didn't) today i switched back to 500cc, because in the past 6 days ive had nothing but problems, the car just feeling very slow sometimes, I did i few pulls yesterday, (still on 1000cc) and i noticed the boost safe was activating, (which would make sense why it was slow) but i just filled the methanol.
the first couple pulls today on the 500 were still bad, but less knock, i messed with my afr a lot to get it proper, and kept tweaking small things, after about 5 good pulls without it messing up i believe i have got it working pretty good, so if anyone has these problems in the future, consider going with a smaller nozzle.
on this pull i hit 387hp (according to dsmlink which i know isn't accurate) I can't log boost yet, but I'm on 24psi
