1G Talon front turn signals not working
Joshua Tadich
56
18
Jul 15, 2018
Pittsburgh, Pennsylvania
So my front signals on both side are not working. Figured it was a bulb so I bought new ones and plugged them in. Without the headlights on they dont light up at all. Turn on the headlights and they stay on but dont blink. Checked the fuse and its was good but replaced it anyway. The tears work just fine just blink fast. Put on the hazards and they blink at a normal speed but the fronts just stay illuminated. They dont work at all unless the headlights are on. Any ideas?
Looks like the wires themselves have power, i swapped connectors and still nothing. I'm thinking the connector in the picture is somehow the problem. I can read power by probing the back of the connector but nothing from the front. Gona have to pull the pins and see what's going on.
Check all fuses in bay, wiring, and the turn signal relay, grounds too, possible the issue could be the turn signal switch on the steering column.
