1G 1g rear Differential/Subframe torque spec
AWD-Tony
6,801
3,735
Sep 11, 2017
Cincinnati, Ohio
I had to jump around looking for these specs, so here it is all on one page.
Top 72-87 ft lbs (100-120 Nm)
Side 72-87 ft lbs (100-120 Nm)
Rear 58-72 ft lbs (80-100Nm)
Inner lower control arm 65-80 ft lbs (90-110 Nm)
Drain Plug 43-51 ft lbs (60-70 Nm)
Fill Plug 29-43 ft lbs (40-60 Nm)
Cover 22-30 ft lbs
Boomerang 80-94 ft lbs (note the orientation of bottom cup)
Rear subframe nuts 80-94 ft lbs (note the orientation of bottom cup)
Lower bushing bracket bolts 51-61 ft lbs
Axle to cup 40-47 ft lbs
Axle nut 116-159 ft lbs
Pff, you put your torque wrench in your purse after you're done? Breaker bar on all bolts until you can't go any further. Red loctite. All bolts. Then unload a couple magazines worth into the air.
:f-u: :D. Only you Vegas!
Like this? :p
Don't be like my brother.
