Murdertalon
- 398
- 86
- Jul 7, 2016
East side,
Washington
I just pulled the end plate on my 2g manual transmission because something has been rattling weird in there.
the synchro on the end of the upper gear set just fell out.. ?
is this synchro supposed to be attached or does it float on the spring in the end plate only?
https://www.dsmtuners.com/threads/noisy-wearing-reverse-synchro-reverse-gear-brake.264928/
this seems like what i have going on its the reverse synchro that rides the wavy washer the gears ect look fine.
anyone have other thoughts on this?
i may have directly caused this before when i installed a clutch master that was pushing too hard on the tob and fork sheesh...
likely going to put er back together and live with the rattle since i know what it is until i save up later to do a bad ass trans rebuild.
