BLACK'98DSM
5+ Year Contributor
- 4,450
- 1,889
- Feb 9, 2019
Alabama
See the new post from @EVLGSXFound the supposed car from "The Hangover" listed for over $40k, it was also a GST. That is crazy to me..
I exposed them
You can build either one of them to be fast. Boostins car did away completely with the stock 2g rear end setup that bolts the pumpkin to the subframe with 3 bolts. They have a custom cromoly subframe with a 3000gt rear end.Seems highly opinionated. You just like 1gs more which isn't a bad thing but the current fastest dsm is a 2g so doesn't mean you're knocks on the rear diff and avenger interior are biased.
Either way 30k for that car is hilarious.
Collectors don’t buy modded cars anyway.
I’m also getting 1200+ horsepower out of stock 6-bolt cranks. Try that with a 7 bolt crank, it’ll break at the 4th rod journal.
Name a mechanical attribute that is better on a 2g, that provides a measurable increase in strength or performance.Does everyone who owns a dsm try to build a 1200hp car? Because I never had and likely never will. I still feel you're just biased because you like 1gs more.
That's a $3000 car, all damn day. I suspect they just added a zero by accident.
I've always wondered what would happen if you did the opposite.. So posting a $3000 car but forgetting a 0. If someone offered you the $300 would you have to accept? I'm assuming if the poster is a dealership then they would have to honor it but on CL I would imagine it would be easy to get out of.That's a $3000 car, all damn day. I suspect they just added a zero by accident.
There are some who would argue that the suspension design used on the 2G makes it better suited for building up a road race car... but then again, the 1g chassis is known to be far more rigid. Plenty to debate about. Everyone can argue different points about which one makes the better starting point, or which one is the most desirable, but nobody should get defensive about it here. We're all family.Name a mechanical attribute that is better on a 2g, that provides a measurable increase in strength or performance.
I love all them and have had every 90’s turbo mitsu sold in America. The 2g Dsm guys are just fun to poke. Same with evo 8+ owners.There are some who would argue that the suspension design used on the 2G makes it better suited for building up a road race car... but then again, the 1g chassis is known to be far more rigid. Plenty to debate about. Everyone can argue different points about which one makes the better starting point, or which one is the most desirable, but nobody should get defensive about it here. We're all family.
