Sam's GSX
5+ Year Contributor
- 395
- 54
- Jun 10, 2018
Hohenwald,
Tennessee
Just found out about the idle switch when grounded to use secondary maps, this is an awesome feature if it works correctly, and I even asked here if there was a way to run lower timing when my meth fails, (they just said I'd need a standalone ecu) my main question is which wire is it (I believe people said it's on the tps, just making sure which one) and do I just cut the wire and run it from the ecu to the boost safe wire? (Grounded when meth fails) I already have scramble boost connected to the boost safe wire, and if this works, when meth fails, boost will drop to 15.5, timing will drop and fuel will be added.
Thanks guys.
Thanks guys.
