Tribal_RS_96
- 92
- 0
- Aug 19, 2011
St. Louis,
Missouri
Hey, Im still looking for a 420a shortblock because mine is spinning a bearing......I think so I cant drive.. Its a heartbreak because this project took a year and a half. I have a video, i will post in a few
The details of what happened at the end of the project:
1996 mitsubishi eclipse with a 97 eclipse 2.0 420a N/A engine in it. The car started up when I found the problem, crankshaft position sensor broke off. I bought the car for $200!!! With a title!
I drove it home and it ran great, no rattling or anything. I parked it for two days to get a temp tag, when i went to start up before going to get a safety inspection It started rod knocking... at idle the knock is constant, when revved at 2k rpm you can still hear it... My guess is the oil pump failed and is leaving my engine starved. I have a magnetic drain plug in, so what possible little metal shreds in the engine cant possibly harm it...right???
I checked my oil from the dipstick, and i dont see any sparkles of metal, and the oil level is full, so it could be spun bearing(s)?
But on to the real reason of the thread, Im looking for a shortblock until i can rebuild mine to my satisfaction, turbo possibly, forged rods and all. But I've been hearing I can use a dodge neon block assembly and pair it with my 420a head. and vise versa.
I can tow the car to my tech class and swap the block out, i hear its possible to repair a minor spin, but my tech instructor is flipping out about that idea because of the metal shavings (small amount possible) in oil holes and cycling around the engine.
My questions are will i need to do anything else? mods to the block like creating holes?
What year neon engines will this work with? i know most 95-99 models, but what about the newer 2000 engines?
thanks for the help, I would love to dive into this swap and have my fun dsm back. Im on a budget so, any ideas and suggestions are really appriciated.
Video:
http://www.youtube.com/watch?v=SEZQjgRNn6w&feature=player_embedded
Video:
