- Thread starter
- #101
Got Grip
20+ Year Contributor
- 289
- 261
- Sep 17, 2002
Philadelphia,
Pennsylvania
The primary and secondary injectors needs to be both the same style? Both hz or both low impedance injectors?, or it will manage both style.
No, with a Haltech with 8 outputs your primaries and secondaries can be whatever you want them to be. You could technically make every injector different in Haltech but I wouldn’t recommend it. Different primary vs secondary is very common though, you just need to setup your injector driver accordingly for each injector or stage.
