Drag Race Build my journey to a 9sec street car
That nicop is easy to work with, it just scares me how quick it turns green and nasty
i found a company that we have that makes complete replacemnt ss hard lines but i really dont want to drop the subframes to get it up in there. it might be something i look into in the future possibly but the nicopp should do ok for the time being.
Mine is still shiny. I didn't think about the copper in it making it tarnish. :rolleyes:
Well, buy then, you can get those stainless pre-fab jobs. :)
I am really happy with the feel of my brakes after I changed the lines and they looked like yours, terrible. We unbolted all of the line brackets under the car that held the original lines and used those where we could, which was most places, just so you know before you get under there.
sad part is the last time i drove the car the brakes felt really good LOL it sat for a little while i was waiting for some other stuff to happen that ended up not and then all of a sudden it was busted LOL
Well, all in all, I am happy that it happened to go out while you were at home and not at the drag strip!!!
Yep, mine popped in the shop, thank god for both of us!!!!
Replaced all mine ill find out how they feel next year got my lines from blains farm and fleet here. Should be good.
Update:
Finally got some time to work on brake lines. Started out by modding the old stock hold downs since there’s only two lines going to the back that will fit in them now LOL
Once I got the brackets cleaned up and modded it was time to start running lines
The passenger side line I’m not 100% happy with so I’ll probably be re running it down the road but for the time being it will do just fine.
Filled the reservoir with some dot5 and began gravity bleeding everything. Thankfully all the flares I made didn’t leak LOL. I was home alone so that’s about as far as I got for the moment. Gonna bleed the whole system for good Measure and it will be done. Then it’s on to put the bat back together and then a couple interior things.
Dot 5? There's some compatability issues there, Dot 3,4 and 5.1 you can do, but not 5.
its been on dot5 for two years now and has had no issues stopping the car? i guess i should note that ive already flushed the whole system previously when we put the car together and ive been running the dot5 stuff.
Engine is back together for the most part. Throttle cable need installed and t bolt clamp on the throttle body needs tightened but it’s running again
On startup I did find one of the upper injector seals was leaking pretty good. Gonna have to order those now.
still need to put a couple things back in the inside of the car but its getting there
We wrapped our rear brake lines, where they are exposed in the wheel well, with vacuum line that I split down the middle and then zip tied it to our lines. Just to keep debris (rocks) from hitting it and possible putting a hole in it. I thought I had a picture of mine but I can't find it. You get the idea though. Just as a precaution. :thumb:
hmm never thought of that. might have to get some line and do that then LOL thanks for the tip marty
Sure, anytime! It was just because the original lines had the metal wire wrap stuff around them out there so I thought that I should try to protect that part somehow and that was super easy to do. Just a suggestion. :)
yea i didnt even think about it when i done the lines. good thing is that i can still get to them pretty easy to add to them LOL
Injector seals showed up a day early
going to get these thrown in this weekend. Might take it to the local cars and coffee sunday. Still a few more things to do to get it 100% but it’s on track.
Glad you got your seals Josh, I always keep at least 4 on hand at the house at all times, sometimes 8.
When I did my son's rear dif in his Z28 this week, we had to bleed the rear brakes since it was all new and I came across this and LOVE it. It gets 95% of the air out. I had ONE burp of air after using it and it was so much handier than "pump, pump, pump" and "bleed", repeat. Just wanted to share. It works off of air like my pneumatic A/C vacuum pump.
heck ya thats awesome marty. the speed bleeders seemed to have worked well for me. pumped them all about 4 times each and all the air was gone out of the system. technically only needed about 3 but did another just for good measure.
