jed344
Supporting VIP
- 1,198
- 301
- Jan 10, 2008
Waterville,
Iowa
Car has 2150cc injectors and currently -8an feed with fuel lab fuel filter. My single walbro 450 is about tapped out looking at fuel press logs. Has anyone ran a radium surge tank with 2 450's and found there flow limit? I am trying to get enough fuel supply to be able to max out the 2150's on e85, also if the surge tank is mounted in trunk does that require a firewall or not. I am unsure if it counts under same rules as a fuel cell mounted inside car.
