2G Various weights of items/parts, some universal items
Just going to log everything here in 1 place for weights from a range of items/products and 2G specific parts of the car.
I hope to have a good catalog of items listed from wheels, tires, brakes etc etc to replacement parts and bodywork/trim. (Note that stuff cut off the car will vary) but a general idea of cut material is a good estimation of weight for everyone i hope.
All items will be per item and in LBS / Oz.
I got many items to weigh and shall update as i go along and can go back to parts easily doable
oem fwd shocks/springs front 11.5, rear 9.02,
Koni yellows and apex springs, front 11.7, rear 10.96,
BC BR coilovers with spherical upper mounts and BC own springs front 9.0, rear 9.0,
oem knuckles with bearings and studs 23.4,
Modified galant knuckles with evo bearings and arp studs 22.6,
oem single piston fwd calipers with pads and hardware! front 13.1 rear 7.1,
Oem dual awd piston calipers 8.03 and mounting bracket 3.96
Evo brembos with stainless racing pistons, front 9.5, rear 5.8,
Fwd oem sized front DBA4000 rotors 10.7, rear EBC GD rotor 9.0
evo sized rotors, front X3E motorsports 2 piece 19.3, rear comline 1 piece 14.8,
Carbotech XP10 front pads (evo caliper sized) 2.11
Carbotech XP8 rear pads (evo caliper sized) 1.1
oem brake booster no test done, (to follow)
Evo 9 booster and mc 10.3,
oem brake lines and prop valve no test done,
JNZtuning full front line kit inc prop valve front to calipers 2.3, rear caliper lines 0.3,
A/C pump, 13.8, / bracket 6.4,
oem fwd exhaust system, DP back to tip 46.2,
previously made system 1.2mm walled stainless with muffler 15.4, Ive not reweighed my new rear exhaust section yet since the redo and loss of muffler,
Oem front seats non powered front 44.0,
OMP TRS-E bucket seat 22.7,
Evo steering wheel and air bag 4.3
Red alto automatic rebuild kit 8.6,
6 piston FM-Endurance PRO billet calipers with bracket 9,
2-piece fully floating 360mm rotor TBC
Deatschwerks IL350 pump and clamps 2.7
Frontline water pump block offs (both) 0.11
G-Loc R10 compound pads for bigger calipers 2.14
Konig hypergrams 18x10.5 et25 19.4, with 295-30 tires 45
Bridgestone DHS AE034 wheels 17x8.5 et36 with 245-40 tires 47.5
Omp steel 3mm bucket seat brackets 5.5
Own-made 5mm FIA regulation alloy brackets 2.8
This post just so happens to be about cam gears, no specific reason but i had 4 to choose from and i have weights for them.
the first set is skunk2 Pro camgears, these are both DSM and EVO compatable and the lightest cam gears we can get anywhere! 343 Grams which is 0 Lb 12.099 Oz! thats damn light! thats under 1lb per gear!
second is the original Skunk2 camgears, these are the redesigned versions as they used to have a different look when they first was released so i dont know that difference im afraid.
these weigh in at 433 Grams which is 0 Lbs 15.274 Oz, this is still light and also under 1Lb per gear.
next up is a real HKS cam gear, it comes in at 1 Lb 1.8 Oz
then we have a fake HKS cam gear and this is less then the genuine unit at 1 Lb 1 Oz!
Was given this AEM cam gear to show up. They are 445 grams which is 0 Lb 15.69 Oz.
Fidanza cam gear, They come in at 534 grams or 0 Lb 18.83 Oz.
Some window action.
I will add the oem front door glass in a day or two,
So poly windows here, they are normmally upto 50% lighter. These are 4mm thick and approved my FIA/MSA here in the UK so its what i went for. 5mm is for rally
The fronts have locking sliders in and these weigh in each at 5 lbs 2 Oz.
Oem glass front 11 lbs 4 Oz
The rear quarter oem glass i do not have currently as its on the car still (to follow)
The poly window though weighs in at 1 lb 8 Oz.
Next up will be the rear hatch window (also to follow)
Rear window 2G 22.2 Lbs
