Hi I’m a young Car Enthusiast and I want to mod this car to a fast sleeper car. I got this car about a year ago. I absolutely love it! I want to do many things to this little beast but I don’t know much about brands that are good and brands that are bad. You guys can give suggestions or better ideas feel free!
The Mods I Want To Put In:
exhaust manifold with external wastegate,
ported 16g turbo,
front mount intercooler,
blow off valve and an upgraded fuel system(braided lines,
bigger pump,
bigger injectors, possibly a fuel pressure regulator)
a manual boost controller,
upgraded clutch
as well as an eprom dsm ECU and ecm link to tune the car to run healthy with the modifications and the corresponding gauges to monitor things correctly.
Get ECMLink first. Then injectors and pump, then a boost controller. That will get you a pretty nice bump in horsepower and you can learn what more you need from there (probably a clutch).
Ok thanks I will do that first but where could I go to get an ECMLink?
So I had an issue with my suspension and I changed both CV axles and replaced my whole suspension with a new OEM front suspension with the help of my dad. I posted a video about the whole process in the timelapse format on my youtube channel called The Fred Rider!
Can you do it by yourself?
You'll need to open up your ecu and see if it's e-prom. Follow this link and the links within this thread. https://www.dsmtuners.com/threads/how-to-identify-an-eprom-ecu.337343/
Once you figure that out, you will need to send in your ECU to ECMlink for them to modify the ECU; or you can buy a used version of ECMlink off of the DSM facebook groups, the classifieds here, or another avenue. You'll need a laptop in order to access ECMlink. Having the ability to look at all of the data in the car will help a great deal as you begin to modify and change parts, run into issues, etc.
