2G Turn Signal Fuse Access
Kai Hefner
Freelancer
480
272
Jun 21, 2018
Calgary, AB_Canada
Long story short I’m pretty sure I popped the fuse for my turn signals. If I’m not mistaken, the fuse box for them is located basically right underneath the passenger-side airbag. Is there any way for me to access the fuse and push it back in without pulling the dash? (FYI I already fixed the issue that caused the fuse to pop)
Theres a fuse box located under the drivers side dash behind the kick panel, and another under the hood. Pretty sure the turn signal fuse is in the interior one. Neither requires the dash to be removed to access. Nothing on the passenger side except for heat/ac components.
