Heli coil failed
Ces4rDSM
119
6
Feb 2, 2019
watsonville, California
I had to instal 2 heli coils for my exhaust manifold studs due to the fact that the threads broke on the 2 holes, my first heli coil did fine that is until I took my exhaust mani off and reinstalled but both heli coils ended up losing tension when I torqued the bolts. Now it looks like every time I torque, the studs appear to come out of the hole again. Same problem. Now how should I repair ?
send it to a machine shop and have them weld shut and then have it re-drilled and tapped to
metric 8x1.25 it will not be cheep but it can be done. depending on how much you have invested in the cylinder head, you might consider finding another head, especially if it's a mostly stock head.
You can try a different type of insert if you have enough material around the hole. Keenserts have a larger OD so you can drill it and retap that hole again.
Worst case scenario is you can drill to a larger size such as 10x1.25. You would of course have to drill out the exhaust manifold holes for 10mm as well but that's not hard.
Can’t count how many helicoils I’ve installed over the years. Prob over 10 on just my current dsm and never had an issue with it coming loose. Is it possible you used too big of a drill bit? Think I’ve installed 4 for the exhaust manifold and a lot for the valve cover.
I get your frustration and hope you get this sorted.
To be honest with the amount of space I was working with, and the time on my hands the heli coils were done decent. My guess is the threads holding the heli coils broke. Or maybe I torqued the bolts too hard. I was torquing the bolts to 28 lb of pressure
The a
That's probably why. 22 lbs felt too little for me so I usually torque them to 25 lbs but this time i went 28 lbs
Probably. The aluminum used to cast these heads weren’t the best.
