Louis Gibson
- 0
- Jun 23, 2019
Tillamook,
Oregon
I’m in dire need of help as I am confused to what’s wrong with my eclipse
97 eclipse GST
Has a 7 bolt 4g63t with NO crankwalk (trust me)
Engine mounts are secured and in good shape
Has newer clutch
My bro and I just tightened the timing belt on the eclipse and got all the timing marks aligned and got everything put back together only to figure out that the car now has a vibration to it when in idle, high rpm, low rpm, doesn’t matter.... to best describe the vibration, it feels like you’re sitting in a massage chair... the engine runs amazing.... it takes whatever I throw at it performance wise.... the car starts like a champ and drives like a champ...... the vibration is especially bad when the car decelerates... i
This is very confusing and I’m not sure where to go from here. Has anybody experienced this problem with their car?
(Again.... never had this problem UNTIL we tightened the tension on the timing belt. (And yes we made sure that the balance shaft pulley was aligned up with the rest of the system.))
97 eclipse GST
Has newer clutch
